Brake fiat ducato 1990 2.5 TD
In the van
A van
Over 25 year's
Has any one had any experience with the brake balance arm on the rear brakes on the fiat ducato
think theirs a problem with it
thanks in advance bill
What seems to be the problem?
Not much to go wrong with the arm,
The spring con come adrift or the valve siezes sometimes
Makes little odds on the average MH - the vehicle is close to fully loaded all the time so the brake proportioning valve will be fully open. If it isn't leaking it's probably a bit irrelevant.
the braking is down on one side right side
bill
The valve with the arm affects both sides equally - it's designed to vary the front / rear brake balance depending on vehicle load. If only one rear brake is down (I'm assuming footbrake) it's likely to be a leaking or seized wheel cylinder.
Reactions: DBK
Concur
look's like slave cylinder has seized will have a better look tomorrow might as well change both and the brake shoes to
thanks very much for reply's
bill
