Boxer indicator fault
Slingsby
Southsea, Portsmouth, UK
Nearly
On a trip round the N500 and the indicators have packed up. Hazard lights work OK but also found that the headlamp flash is not working either. Any ideas anyone?
Probably a fuse. But could be the indicator stalk.
Dunno how old yours is, but on my 2004 Boxer, the indicator relay is directly behind the hazard light switch, possibly even an integral part of that unit. Given the hazard lights work, and the things that don't work are all on the stalk, I'd also start looking there first.
Had exactly that on my Renault Master and it was the stalk.
Got another unit off a Renault Scenic from the scrappy and it was great until a month or two later, when I went to use the horn and found that the Scenic didn't have that function on the stick !
Got another from an online breaker which worked great.
Don't even think of stripping it down to try and fix it, there's contacts, balls and springs that just want to fly off everywhere. :X3:
Thanks all. I've now changed the stalk and the panel with the indicator control and hazard warning switch but the problem persists. I've also checked the continuity from the switch to the control unit and all seems OK.
Does anyone know if there is another separate flasher unit anywhere I could check?
What age is your Boxer, I think some of the newer ones control the lights etc via a Body System Interface rather than with relays and there's a few videos on YouTube showing how to reset this as it seems to be a common fault affecting random things like electric window operation, lights, indicators and wipers too ?
