Boxer flashing eml
autosleeper
hi please help 🙏🏻🙏🏻 Recently purchased a 2013 Peugeot boxer flashing eml found it to have a faulty glow plug on the dpf vapouriser so was blowing fuse in engine bay a 20amp got a genuine Peugeot vapouriser and have fitted now and completer a regen but eml light comes back on after with a engine power limitation fault code po62c anyone had this many thanks
This code not in my Fiat database so a quick search​
Code P062C Description​
The diagnostic trouble code P062C indicates an issue with the internal control module vehicle speed performance. This code typically means that the vehicle's control module is not receiving the correct signal or information regarding the vehicle's speed ie it
has detected an internal performance error with the vehicle speed sensor (VSS) signal.
Read more at: https://www.obd-codes.com/p062c
Copyright OBD-Codes.com
probably totally irrelevant but Fiat codes P062B, P062D relate to injection system. (no p062C codes)
