The side lights and the high beam work ok. The fuses are fine and I will check the bulbs once it stops raining, but I doubt it's the bulbs as both are not working. Next thing to check is the relay and then the steering wheel stick headlight switch. I have enclosed a picture of the interior fuse box which is located near the drivers door. Does anyone have a diagram of my fuse box (Fiat Ducato 2014 X250 model) to show where the dipped beam fuse is located and also how to remove the metal casing which covers the left and right sides of the fuse box?
Update: Also noticed that the hazard warning light switch in the center console does not flash (the exterior hazards lights all flash though). I wonder whether this is connected and maybe this unit that contains the hazard switch also controls the dipped beam?
