hi,I would have thought Presumably your current BMS only caters for 4 cells in series ? So won't be able to balance 8 so you will need another BMS (preferably identical and then parallel 2 x 12 volt batteries,or an 4 S 2 p 12v of the desired current.
Maybe someone with more knowledge than me can confirm wether I'm right or wrong
It should be okay if done like thishi,
i was hoping to pair the cells up with bus bars, so that i can use the 4s on the 4 pairs. not sure about the balancing though.
If you parallel pairs of cells, then series 4 of these pairs it will "work" but although it will balance ok, it will fail badly when one cell in the pair goes bad.hi,
