- Jul 6, 2009
- 2,323
- 2,996
Should the BMS cut off the Lithium leisure battery when the voltage is low and if so what voltage. Looked at mine this morning showed 0 volts everything dead?
If the BMS cuts off the battery when it's low it will probably show zero because it is cut off. Put some charge in via solars, if not on EHU, and then you need to find out why it dropped.Should the BMS cut off the Lithium leisure battery when the voltage is low and if so what voltage. Looked at mine this morning showed 0 volts everything dead?
