Blaupunkt Dortmund 230 DAB car Radio £125.00
It came fitted in my van but I changed it for a double din unit, this has had little use, disc only used once to test.
It can also be set stay on an hour with the ignition turned off, and plugs straight in to the iso socket
Complete with box instructions and remote. and is compatible with android and iphone.
Spec From Internet
Radio
Spec From Internet
Radio
- Built- in DAB/DAB+ tuner
- DAB Band lll / L-Band
- Service link (DAB-DAB, DAB-FM, DAB-DAB-FM)
- Service selection by ensemble
- Automotive FM/AM tuner
- Radio Data System (AF, CT, EON, PS, PTY, REG, TA, TP)
- Travelstore
- Built-in Bluetooth
- Profiles: HFP, PBAP, A2DP
- Built-in microphone
- External mic connector
- Auto wake-up (if radio is off)
- Plackback formats: MP3, WMA
- Fast playback from USB, SDHC
- MP3/WMA comfort browsing
- Selectable display modes (ID3-tags, folder, file, play time, clock, all mode)
- Made for iPod/iPhone
- Android music player App
- CD-DA, CD-R, CD-RW
- USB
- SDHC, SD
- Front USB (standard A-type)
- SDHC-card slot (behind panel)
- Front Aux-in
- Steering wheel control input
- Sound presets (Rock, Pop, Classic)
- X-bass
- 4-channel Preamp-out (4 V)
- Separate Sub-out
- 4 x 50 Watt Max. power
- Release panel
- Permanent preset memory (after battery disconnect)
- Panel case included
- IR remote control included
