Bike Security - Once Bitten, Twice Shy
mhf051990!
I've noticed some posts on bike security, so here's my experience and solution.
In Gothenburg, Sweden I had my e- bike stolen, not from the back of the MH but at a bus stop bike rack cable blocked with many other bikes.
4 hours later I returned to find my e-bike gone along with every other bike in bike rack 😭
I had removed the battery and the speed controller display.
Made no difference to these thieves as they would simply break the bike down and sell it of for parts.
After awhile I bought another e-bike but instead of a cheap garden variety cable lock I bought a very strong multi-strand high tension flexible cable (see photo)
Then I bought 2 Kryptonite disc brake 110 Decibel screamer that are activated by any movemeuof the bike.
Yes, over kill but I doubt if anyone could carry the bike off very far with 2 x 120 Decibel screening sirens blaring out.
Being an Engineer Im a "belt and braces" sort of person.
Ok, already got the "belt and braces" with the sturdy cable lock and 2 Kryptonite disc brake locks.
But I then dismantled the black battery holder from the bike frame (see photo) and inserted a GPS Tracker on top of the motor, then replaced the battery holder box.
As a final, "give it all I've got" approach, I then attached the sticker on the frame (see photo) warning, This Bike Is Fitted With A GPS Tracker".
Hoping this deters all the amateur thieves and some of the professionals 🤔
To end this tome, shortly before my bike was stolen a couple I was traveling with, the husband had his €10,000 mountain e-bike stolen in Copenhagen while we were watching the women's world cup football match between Denmark and Australia.
He had it chained to a tree with 3 humongous hardened steel chains.
When we returned the bike was gone and the severed chain links lying on the ground.
Professionals had come with a battery powered disc cutter and cut through the hardened steel chain like a hot knife through butter.
The Danish police advised they only recover about 1.5% of stolen bikes.
Long story, short, some weeks passed and he had a call from the Danish police.
They had recovered his bike as part of a load of 600 stolen bikes on a truck heading out of Denmark 😱.
He drove back from Germany to collect the bike, but the police wouldn't disclose why they stopped the truck and searched it.
I can only imagine, at least one bike must have been fitted with a GPS Tracker 🤔
Our ebikes require a code to stitch on, has an inbuilt tracker and audio alarm if moved without the connected phone but nobody knows that except us so a sticker is a good idea thank you.
This is in addition to a Gold standard lock and a 'Dutch' wheel lock on each. The Skarper electric gismo that converts a removable conventional road bike to electric, endorsed by Chris Hoy, seems like a good solution as you can attach it to a beaten up old bike that nobody would thing of stealing. for those wanting to carry them on a rear bike rack it would make the bikes much lighter than a cica 25 kilo full on electric bike (20k without the battery).
I used an Oxford type motorcycle lock .....casual bike theif won't get through that in a few minutes except with an angle grinder.
With the advent of battery grinders don't expect any lock to be effective.....just use it to satisfy insurers.
I've spent quite a few quid good "Sold Secure" locks but consider it to be a waste of money. Because, rarely in town do we find anything "Sold Secure" to lock them to.
No lamp posts around you Jim?
I would avoid anything MasterLock If I were you. They are notoriously weak and easy to pick.
I got a lock pick set and was able to pick my 2 master locks within minutes of learning how to operate a rake pick.
If you don't believe me watch either The Lock Picking Lawyer or McNally.
The lock picking lawyer is much more informative and serious. McNally puts on a bit of a show.
With either of them, type masterlock into the search box. You will not be happy. They are a massive joke in the industry and never improve even when flaws (usually trivial) are pointed out to them.
It's actually an Oxford but couldn't find a picture
A decent concrete lamp post might be OK, But even then, your like causing an obstruction by chaining a bike to one All the bike parking tubes and the street furniture and railings that the majority of us use with expensive locks, can be cut through in seconds. Once they have the bike they can remove the lock in the "thieves' workshop" with ease.
Never heard of them. Just went a watched the 1st one on the Lock Picking Lawyers channel and found this.
It took him more than a minute to pick which is an excellent sign and he didn't spot any obvious flaws. Good choice I think.
Spend all this money on carbon/titanium bikes only have to carry around 10 tens of anti theft devizes.
I wonder why there are no car park inclosed areas for bikes with security guards, pay a fee for the day or just convert parts of existing car parks for bikes.
Someone needs to invent the flame thrower bike.
I did a lot of research when getting security for my bikes... and basically ANY cable type lock are worthless .. any cable cutters even ones you can hide under you coat will easially chomp through most cable type security systems..
IMV you can't beat a grinder proof bike lock i.e. 'Litelok' but they are limited to what you can attach them too, and as Jim says, they won't easily grind through the 'Litelock' but the bike rack, fence is another matter..
Walking around Bristol yesterday I was amazed by the number of cut up/mangled bike racks..
Just check facetube videos of the scrouts blatantly stealing cycles and mopeds. Approach them and they attack you with said angle grinder.
Best not to leave them unattended..... yes I know, not perfect..
I use a X1 and a X3 Litelock which are very resistant to angle grinder attack.When we are home with the bikes I put them through the front and back wheels of the motorhome as an additional level of security on top of others, plus with my motorcycle so get plenty of value from them.
Went to watch a football match in Copenhagen and came back to find thieves had cut through 3 hardened steel bike chains in a busy street.
They took my friends €7,000 mountain e-bike and left his wife's €4,000 e-bike lying next to the tree the two bikes were chained to, with 3 chains!!
Obviously, they were only after high end bikes 🤔
Luckily to say, he got it back when the Denmark police stopped a truck with nearly 600 stolen bikes 😱
Maybe one of the stolen bikes had a GPS tracker, but the police wouldn't say why they stopped that truck.
Guess it's the luck of the draw 🤔
