Bike rack, ladder and awning, Autocruise Vista
Ludgershall, Hampshire
Autocruise Vista
I'm a newbie
Spent the weekend looking over my new motorhome and trying to work out what needs doing.
It came with a Fiamma Bike Rack framework and ladder attached along with an unused Kampa Rally 200 awning.
1. I want to carry a Freego Eagle E-Bike and a standard Hybrid on the back. Would it be more sensible to buy a whole new rack for e-bikes or just the fixings with telescopic rails so I can open the rear door? I haven't measured yet, but suspect the bikes will project out onto the right hand side, so that would be a non-starter anyway?
2. It looks as though the awing can mount to the rear rail, but I am unsure if that will work with the ladder in place?
3. Will I get any use out of the ladder? There is only the solar panel on the roof and no real room to mount anything, should I just use a normal ladder at home to access the roof when I need to clean and inspect it? Is it just a case of unbolt and bung the holes?
Still a newbie, so sorry of these seems like daft questions!
In my view the rack will not work for cycles, sticking out and blocking door. The awning would need the ladder removing. If you don't have a roof mounted storage box then yes you can remove the ladder. The door must snag on the ladder?
As an alternate thought to a towbar and bike rack, how about one of the wide step bars I have seen on some motorhomes? I think they’re designed as motorcycle racks running the width of the van but could serve as both a step into the back door and have the bike mounts on either side?
