Beware of Mice (1 Viewer)
Dec 16, 2014
103
73
Sheffield
New
Just had my Elddis 155 (PeugeotBoxer) first major service.Mechanic found 4 dead mice in the airfilter container. He reckons they must have climbed up the wheels/tyres into the engine compartment then onto the crossmember above the radiator.There are 2 oval shaped vents leading to a large intake pipe leading to the air filter.
On taking the air filter out,a section of the paper fins had been eaten away.I can only assume they couldn't find there way back!
Motorhome is parked in a compound of crushed brick/stone in an industrial area.
I can't think of a permanent solution but have put cooking foil over the said vents with another piece on the steering wheel as a reminder
  • Photos (9).zip
Aug 17, 2018
32
24
Basingstoke
Low profile
Since 2016
It seems like a common problem, I've heard of it before and only about a week ago I replaced mine and would you believe it, a dead mouse and nibbled filter.
As you said there is only one way in, how they find it I have no idea.
Mind you, I don't mind them eating the filter if they leave the wiring alone!!!
Sep 28, 2015
2,178
2,870
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
Rat Repel, it’s a powder that you sprinkle around the outside of the motorhome on the ground, it fools rodents into thinking bigger badder rodents live there already.
Worked for us, though it didn’t stop a Blackbird setting up its nest under the bonnet.
I’m not sure Rat Repel is still available but there are other similar products.
Jan 19, 2014
9,763
25,955
Derbyshire
Elddis Accordo 105
since 2014
Put a bowl of poison wheat under the bonnet, they love it. I put some in our garage as a precaution and after a couple of weeks they'd been eating it. Little buggers are everywhere, keeps them out of the shed too if you remember to do it in the autumn.
Two on Tour
10,793
55,669
Elddis Autoquest 175
Since 2010
Maybe a bit on the expensive side but we have no problem with mice or rats. ;)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
@Cobnarowl remember it could also be possible that the mice have been in there for quite a while, maybe even before the vehicle was registered..
GWAYGWAY
4,213
3,308
Dover
Hymer ML I 580
4 years
Try putting some metal gauze over the air inlet to stop it happening again. Trouble is they get in but cannot get out again, would probably make the ideal mousetrap.
As for the squirrel catapult, they forgot to CGI in the plate which evaporated when the squirrel went off.
Grandchildren escapee
12
9
Yorkshire
Globecar Campscout
since 2013
A mouse ate my alternator cable last year. Very pleased when I found out as it was cheaper than the replacement alternator I was expecting to pay for.
steve 6644
648
2,547
Sodding things must have drunk all my beers awhile back. A common problem I would imagine:)
TheBig1
Nov 27, 2011
17,851
44,358
peppermint oil around points of entry helps keep mice away
Sep 21, 2016
4,349
16,722
DERBYSHIRE
Frankia i740
since 2007
I once found a dead mouse in an empty wine bottle in the garage, it got in but couldn't get back out for some reason. Apparently, dead mice are often found post mortem in the lungs of people found dead in their homes. Usually those poor souls who lie dead for weeks before they are found.
Feb 22, 2011
10,427
21,813
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Too much information :sick:
