Norma Lake
Any recommendations for a lithium battery for an Elddis CV20 (2020). We do wild camping and feel that solar panel isn't enough to keep the battery topped up. Thank You!
If the battery is charged you won't see hardly any output from the solar panel just a low current float charge. Run the battery down by at least 25% then you will be able to see what the solar is doing.Thank you. The battery is new. The leisure battery is siting with a good reading so not sure why the solar panel is not great.![]()
Battery from KS. Energy 100ah Bluetooth + Victron 30 amp b to b charger you can stay away as long as you want as long as you have diesel.Any recommendations for a lithium battery for an Elddis CV20 (2020). We do wild camping and feel that solar panel isn't enough to keep the battery topped up. Thank You!
In winter, solar is generally not enough. You can get away with it in shoulder season with plenty of panels and an MPPT. Lithium can help because it is much more electrically efficient. You can also get a lot more capacity into a given space/weight. It also plays nicely with high powered B2B chargers, so you can get a substantial charge when just driving around. Lead acids prefer lower charge rates.Any recommendations for a lithium battery for an Elddis CV20 (2020). We do wild camping and feel that solar panel isn't enough to keep the battery topped up. Thank You!
Thanks, much appreciated. Once you start to think about your usage that can of worms gets bigger and the string longer!In winter, solar is generally not enough. You can get away with it in shoulder season with plenty of panels and an MPPT. Lithium can help because it is much more electrically efficient. You can also get a lot more capacity into a given space/weight. It also plays nicely with high powered B2B chargers, so you can get a substantial charge when just driving around. Lead acids prefer lower charge rates.
However, there are far too many variables to be recommending specific products. You need to be clear about your usage profiles. How much driving every day? How long off grid? Where in the world? What seasons? What heavy loads do you have? Compressor fridge? Diesel heating? Inverter? Hair dryer? Electric cooking appliances? Massive gaming laptop? TV once in a blue moon or 10 hours a day? Tank heaters in cold weather?
