Best dehumidifier (2 Viewers)
PP Bear
8,306
31,499
Kent, UK
Auto Trail Dakota SE
Iā€™d absolutely bother, as do lots of other Funstersā€¦
Iā€™ve been using this for past 12 years and it never ceases to amaze me how much moisture is in the air. Itā€™s ok saying thereā€™s plenty of ventilation, but if itā€™s cold damp air coming in, then this is ideal.
More to search through hereā€¦
PP Bear
8,306
31,499
Kent, UK
Talking about vehicles left on forecourts over winter, I walked past a dealership yesterday morning and the inside of every single vehicle on the forecourt was covered in so much moisture, you couldnā€™t see inside it. Came past a few hours later and it had gone. It was still inside, waiting for the sunshine to go back in and itā€™ll be back. Tis the same with nearly all motorhomes on a forecourt.
4,335
7,469
Oxford
WildAx Constellation
Since 2008
I also have one of these and have been impressed with its performance..
58
91
Converted VW Crafter
In my experience, the unibond ones didn't reduce the moisture at all. I'm quite a geek and I had a humidity sensor next to it and it didn't change at all the whole time I had it. Therefore I would recommend a mains operated one.
4,853
9,454
Greenwich, London, UK
Hymer MLT 570
I'd not bother.
You are better off cracking open a window or roof vent and ensuring all bedding is removed and open every internal locker.
rwg
Sep 7, 2021
247
554
Benivan 120
Since 2021
We had an old car which we weren't using and it sat on the drive all winter - mould growing on the fabric by spring due to the dampness building up and not escaping.
I use a 240V dehumidifier set on a low setting in the colder/damper parts of the winter in the van. Since it will be cold in the van, a compressor based dehumidifier will be little use (they work best in warm conditions). Get a dessicant based one (they have a rotating dessicant wheel inside that absorbs moisture during most of the revolution, then is heated to drive out the moisture at one point and then the driven out moisture condenses and collects).
I have the EcoAir DD1 Simple (actually have 2, one for the van and one for an outbuilding with stuff in that doesn't want to get damp/rusty)
cheers,
Robin
71
115
Greater Manchester, UK
Don't have one yet
I'm a newbie
For various reasons, mostly to do with guitars, I started monitoring the humidity levels around our house (in 3 separate places).
I have purchased a few things over recent years, ranging in price from Ā£10 to Ā£150, but if it's not raining outside and there's even the slightest breeze, if I open the front door and the back door, the humidity drops considerably within 3 or 4 minutes.
My top of the range Ā£150 dehumidifier takes hours and hours to achieve the same job.
The process begins again the following morning šŸ˜†
