- Oct 20, 2021
- 136
- 115
- Swift Kon-Tiki 774
- Since 2017
Morning All!
I bought a 496 last week. 2017 and in pretty good condition. On closer inspection found that the electronic dump valves have been replaced with manual plastic valves. Unsurprisingly as my previous 774 had the same and they’re ridiculously low so prone to being knocked off. There are two switches on the panel above the hab door for fresh and waste. The bracket for the fresh is long gone. If any Funster has a 496 that year could you post an image please? I can make the front bracket but the valve I would imagine to be same as 774, the blue ones readily available I’m not sure are the Tte same - the 774 you pushed “empty waste”, the valve would open then close itself when the tank was empty, I imagine it had some sort of sensor to be able to do that?
Any thought Funsters?
All!
Recently bought a 2017 Bessacar 496
All!
