Bespoke table top required
Mr porky
Middlewich, UK
Morelo Loft
Lots now
Im looking for a company to supply me with a table top for our motorhome.
It needs to be thicker than the usual 15mm thick options (prefer 30mm thick at least)I have seen on the net.
All suggestions welcome.
hi these people made mine for me
Clearcut Conversions Ltd
Richard Williams
3 Riverside Units
Phone:01271 373853
Email:enquiries@clearcutconversions.co.uk
Pottington Business Park
Barnstaple
Devon
EX31 1QN
United Kingdom
I’m sure others have come to the decision that the manufacturers supply tables in motorhome that are too big for purpose.
Our table just eats into the space hence the need for a smaller one but I would like to fit a quality table top not just a thin replacement.
All suggestions are very welcome.
This is what I have replaced our Rapido table with and it works great for us
Not the normal caravan / motorhome table top it's from a catering supplier.
That looks good. Whats it attached to? In the photos looks like its floating.
Swivel arm from Cak tanks ,
Fitted a chunk of wood in the cupboard that it's mounted to and two very heavy duty shelf brackets behind. Very straightforward to remove if we ever sell the motorhome.
Would an expanding one work for you???
Any laminate fabricator will be able to make one for you - joinery companies who produce bespoke units for shop fitting work. Www.lamform.co.uk is one example, I know that company of old, although kitchen worktops is their main trade they would be able to produce something bespoke for you if you couldn’t find anything off the shelf.
Www.stockmartplastics.co.uk is another example.
Look at tables themselves which you can just use the top from ... that's what I did in a previous camper.
The table in my Hymer was massive so I replaced it with one made to my specifications by Rainbow Conversions. It is secured via a Fiamma base, chrome column and mounting plate fixed to the bottom of the table top. It literally takes seconds to erect/demount and is very stable in use. Column clips in wardrobe and the table lives on the drop down bed when travelling.
Thanks @Armytwowheels. great recomendation going to do a second measure then ordering from them the nautical star slide looks perfect.
We have a table from the same range .We have it on an adjustable wall bracket so it leaves the floor clear for the dog. It also folds flat to the wall when not needed. Only thing we found was it needs something substantial to fasten it to.
We like big meals, so big tables, too. The problem arises when the table's not in use.
My boat uses Desmo table legs. The top is fixed when up but it all tucks away when not in use and there are two sizes. So we have a choice of large, small or none.
I am also looking for a table as mine in our Chausson is too big , we are trying to find a Composite or Honeycomb table Top that is approx. 1000 mm (39 inches ) in length by 560 mm (22 inches) and approx. 30 to 50 mm (Inch and a quarter to 2 inches thick ,but has to be composite or honeycomb so we can modify it, so we can cut it in half and fit wood inserts and special hinges to make it fold in two. tried suggestions on here thank you all, Most tables for M/homes and Caravans are made by Quinton and Kaines (QK) Stowmarket 20 miles from me ,guess what don't supply to public. tried to find employee who could buy one on my behalf unsuccessful at present.
I have spent hours looking at this, as it seems I am not the only one looking I will post if I have a result.
Wow, that is expensive. It must be real quality.
I have just taken our table top off and made it much smaller, put new edging on and bingo.
cost a tenner for the edging.
Yes initially I thought yes £400 is expensive but it’s solid teak and it slides from 580mm width to 340mm width that makes a huge difference in the space to move freely in the lounge area of my motorhome. I wish though that it being an a class motorhome it would have been nice if the original manufacturer come up with the great design of a size reducing table top.
let us know the quality and how it is in use please.
