- May 7, 2023
- 13
- 9
- benimar tessoro 486
Hi Emmit, The clip at the bottom of the flap has snapped. Blutak has done a wonderful job so far but..?Is it a direct swap you're looking for.
I only ask because the photo's you've provided
don't look as if there's anything wrong with them (other than FW&T)
I too broke the useless catches. Also tried blutack for a bit. Got sick of it flapping in the wind. Get the newer model with the magnetic catch. Only downside is it attracts ferrous road muck so you get two permanent dirty circles on the plastic.
They are quite common I don't think you can buy the flat separately, check the dimensions and mountings as there are a couple of manufacturers.
Campervan Water Inlet Filler FAWO White Magnetic Lid w/ Cap Motorhome WS3.15 | eBay
FAWO external water filler inlet which connects to the onboard water tank, with a white magnetic closing lid and a locking white cap with 2x spare keys. - 1x White FAWO water inlet. A 40mm hose is required for the water inlet to the tank and a 10mm hose for the tank vent.www.ebay.co.uk
Water Inlet with Flap | Water Filler Caps | Leisureshopdirect
Buy a Water Inlet with Flap | Water Filler Caps | Leisureshopdirectwww.leisureshopdirect.com
Great idea, thanks.A couple of small neodym disc magnets glued to each part would sort that out.
Thanks Emmit. I’m one of the Tykes who don’t.You could go 21st Century and glue some magnetic strip to the flap and its receiving cover.
Job done for a lot less than £30.
Not all Tykes live in Gods County!
Update: This works really well. Thanks again, Emmit.Thanks Emmit. I’m one of the Tykes who don’t.
