BCA PDU vehicle battery input, for battery balancer.
Bromsgrove
Eldiss CV60
Since 2020
Happy Easter all.
I have an Eldiss CV 60 with a BCA PDU. Looking to fit a battery balancer but struggling to identify the feed from the vehicle battery into the PDU. Do not want to run a new wire back!!
Any help appreciated.
Can you disconnect the leisure battery and check what feeds are still live, then start enhine and again check voltage are same for feed and engine battery. Obviously this needs to be done with no mains or solar input or you may get a falls reading
If you look at the bottom of the offside B pilar (A is hinge, B is lock) behind the trim you will find the converters socket and you will find the feed from the vehicle battery, you should then be able to follow this to the PDU.
