- Feb 22, 2023
- 77
- 284
- Hymer BMLi880
- Owned a MH since 2012
Just getting used to new set-up, lithium plus new inverter/charger, additional solar, plus a battery master for the starter battery. All working well it seems however I am getting a discrepancy with the starter battery voltage. On my app for the Scorpion Tracker it is always between 12.7 and 12.9 volts, whereas a reading directly off the +ve and ground connections on the input side of the New DC2DC is usually around 12.3 volts. If I go to the Schaudt panel it is usually showing just one of the green LEDs ie somewhere around 12.2 volts.
For information the EBL no longer provides any of the charging functions and the fuse has been removed from the original booster circuit (EBL side 80 amp fuse) although I cannot locate the 70 amp one that is supposed to be next to the starter battery.
Is the voltage discrepancy something that I should be concerned with or should I just accept that if it works then all is okay?
Any advice / comments / suggestions appreciated!
