Something like that, a 150a mega will blow at 1,6 times the value in the best case scenario. That’s 240a running on a 16mm. Try run 100a on a 16mm and see how hot the cable gets within minutes the insulator will go soft. The max on a 16mm would be 50a, but since 30a is needed, the 30a would be perfect choice.I think you might be suggesting that the 16mm cable could overheat and set fire to it’s insulation before the 150A fuse blows to save the battery from damage.
