- Sep 3, 2023
- 16
- 3
- Hymer B780MLi
Hope someone can help, I am having problems with WA121545 not working,(has been sent to Apuljack for testing but sent back as no fault found, only just found out they do not test with sensors fitted) if i disconnect the sensors to it it works ok but will not work with them plugged in, both battery sensor voltages are correct so i suspect the battery temperature sensor.
Can anyone give me a normal resistance reading from a temperature sensor to compare with mine.
Thanks in Advance
Thanks in Advance
