- Dec 30, 2019
- 17
- 5
- Van Conversion
- since 2017
Hi I have two numax110v xv31MF batteries which need replacing. I’m looking at power plus 110v with 5yr guarantee . But not sure what I’m looking for
The XV31F is 105Ah not 110v so maybe you're looking for the wrong spec'n?Hi I have two numax110v xv31MF batteries which need replacing. I’m looking at power plus 110v with 5yr guarantee . But not sure what I’m looking for
Numax batteries are made in the Hankook factory in South Korea.Hi I have two numax110v xv31MF batteries which need replacing. I’m looking at power plus 110v with 5yr guarantee . But not sure what I’m looking for
Thanks I will take a lookNumax batteries are made in the Hankook factory in South Korea.
These are 130Ah so a little taller - check they will fit
DELL T3620 System Case Fan SUNON MF92321V3-Q020-S99/# | eBay
Find many great new & used options and get the best deals for DELL T3620 System Case Fan SUNON MF92321V3-Q020-S99/# at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Yes, I realised that but you may be having difficulty (and as you say: not sure what you are looking for), as you may be looking for a 110v battery (the 'V' is voltage which is not the same as 'Ah' which is the battery's capacity). Your current Numax are 105Ah capacity.Yes that’s what I have now but wanted to get new ones
Did you have to change much to go onto lithium onesMy Numax batteries were 9 years old when I replaced them for lithium. They had lost some capacity but were otherwise going strong. On that basis I wouldn't worry too much about the length of warranty.
I changed my solar controller to one with a lithium profile and added a B2B with a lithium profile.More recently I bought a 2nd hand lithium charger for use on EHU but I don't expect to use it often and I probably could have got away with my standard charger but I wanted to ensure that I looked after the battery well.Did you have to change much to go onto lithium ones
I have the Hankook version in 130Ahnumax110v xv31MF batteries
Thanks so much for the reply, very helpful and I will look at theseIf you've not purchased them already then please consider going for a lead carbon battery, they have many advantages over lead acid and can be viewed as a halfway house between lead acid and lithium.
They can be cycled many more times than lead acid. lead acid typically 200 cycles, lead carbon 1200.
They can be left 50% discharged without internal sulfation occurring which is the killer of all lead acid batteries.
They have a lower internal resistance so the bulk charge phase lasts longer giving quicker charge times.
Their charge efficiency (how much power is put in compared to how much you get out) is much higher than lead acid. (lead acid 85%, lead carbon 95% lithium 97%.)
Ultimately they are a much better battery, mine is 4 years old and still like new, powering a toaster/hair dryer/ microwave/ hob via an inverter no issues.
They don't need any modifications to the existing charge system, they just drop straight in too.
Leoch do a good range and they can be had at Tayna with a 10% discount to CAMC members. The AGMs (what I have) are the cheapest, the gel range have slightly better spec and can be laid on their side if need be but cost a little more.
Hope that helps, Merl.
Yep, I have 2 of these topped up with 400w of solar, never any issues, previously had 2 x 125ah that lasted just over 5 yearsI have the Hankook version in 130Ah
Hankook XL31 Dual Purpose DEEP CYCLE Leisure Battery 12V 130AH 900CCA
All Batteries are Made By Leading Manufacturers This heavy duty deep cycle battery is designed to meet the needs of leisure and marine vehicles. With its sealed calcium construction which makes it 100% maintenance free this battery is fast becoming a favourite within the industry. This range is...batteryfactory.co.uk
