Daveyfos07
Hi Guys, can I ask for some battery advice?
Our fridge works on gas, EHU and also via the alternator while driving. About 3 weeks ago the fridge suddenly started flashing while driving through England. This basically meant the fridge wasn't being charged via the alternator relay
I had a play around with a multimeter and couldn't figure the problem out so I left the van into an auto electrician.
They discovered the problem and believe it or not a snail had crawled in behind my control panel, got electrocuted and damaged the cable going from the alternator to the fridge.
Anyways, the auto electricians sorted it and I drove the half hour home to my house. While engine was running the control panel was on and fridge was working fine. As soon as I stopped the engine the control panel went off and so did the fridge. I tested the terminals of the leisure battery and got a reading of 11.2v. Obviously the auto spark has been working at things and drained the power of the leisure battery.
I now have the van on EHU at the house but the 12v control panel and 12v element of the fridge are not coming on.
I have 2 questions:
1. Is the 11.2v just not enough power to work the control panel, lights, 12v fridge element etc and just needs charged?
2. Has the leisure battery dropped too much to be recharged and reused or should I buy a new leisure battery (the one I have is only 6 months old).
I was going to leave it on EHU overnight and check the battery in the morning but I've heard if a leisure battery ever drops below 12v then it cannot be recharged successfully as it will not hold a charge. Obviously the half hour drive home was not enough to charge it so do any of you think leaving it overnight on EHU will be OK or am I better just going and buying a new leisure battery?
Thanks so much in advance
I have 2 questions:
