Battery Master Connection
Frankia F-Line i640
Forgive my ignorance, is the correct piece of equipment to connect a battery master to so my leisure battery can charge the starter battery using excess solar gain ?
Yes, that's what a battery maintainer is for. There are various brands, including VanBitz BatteryMaster and Ablemail AMT-12. Several other electrics companies have their own version, like Renogy, CBE etc.
Lenny HB autorouter thank you for your replies, would you be able to confirm where I would connect the following wires from the battery master ?
Red wire which should connect to the leisure battery
Brown wire which should connect to the starter battery
Black wire which should connect to the to vehicle ground
From this diagram you can see the connections, it doesn't matter which negative you use.
