Hi All.
I have a tracker on the van that also gives me the engine battery reading. I occasionally check the voltage and it’s normally between 12.7 and 13.5 volts.
Checked today and the reading is 14 volts is normal/high? I have two gel leisure batteries fitted around 18 months ago one solar panel with battery master.
The van is not at home but if there is a potential issue then I’ll drive over and check it out.
Thanks in advance.
Thanks in advance.
