- Feb 14, 2021
- 4,543
- 10,334
- Burstner Lyseo 727G
- 3 years 30,000 miles UK and Europe.. Campsites and off Grid.
I have a 2021 Burstner with a Elektroblock 119.
I wonder if lovely knowledgeable peeps on here can educate me a little.
I have a 175Watt solar panel with an MPPT NDS Suncontrol 2 (SC320) controller (20amps) connected directly to 3 90AH leisure batteries
Both the controller and the Burstner display are a little basic in the info they display. The Burstner display I believe shows the voltage of the battery as it is at the time (resting, charging whatever). Normally in the day it will show up to around 13V and at night 12.7 or less depending on use.
So at the moment it is at 12.7 in full sunlight. I would have expected it to show higher if the solar is working at optimum. The Controller has a red light which means it is bulk charging. The battery would have been a little low at the end of yesterday as I had used it to partially charge an electric bike and accidentally left the outside led/awning light on all night
So the question is - what is the display telling me, currently level of the battery or current charging (input) ?
BTW - I note that the Burstner display is always a level below what a multi meter shows direct from the batteries. 12.7 on the display reads 12.87 on the multi-meter currently and is usually a couple of points above the main display.
