Bathroom sink drain
Leeds
Ih tio
our Rapido bathroom sink drains SO slow it does eventually go .had pipe off shoved something down no good bought all sorts of stuff but no better the shower and the kitchen sink are fine.so any ideas thanks
I had the same problem it turned out that when my van was level there was no fall on the horizontal pipe coming out the waste undid the pipe clip behind sink pulled pipe down so it had a better fall put clip back on sorted.
I am not saying you have the same problem but worth checking.
Is there a trap? the one on our shower was partly blocked with hair:( not mine though.
Martin
Try a "plunger" they work wonders!!
Experienced same problem on a Rapido, horizontal waste!
I stick my middle finger in the water,swirl it around very quickly to create a vortex !!:whistle:
Careful using plungers - the pipework is only push-on and not designed to take any pressure. Too easy to blow a pipe off somewhere totally unreachable........................
I use the vortex trick when sometimes the kitchen sink is a bit slow. Seems to work, 'cos nothing else does!
