Coolcats
- Jan 24, 2019
- 6,239
- 11,077
- HymerCar Ayres Rock
This is an interesting one, I never ordered a water fall feature
I have identified that when I use the Bathroom tap (nearside of the vehicle) the water is not draining into the grey tank but under the floor and exiting via the offside scuttle it drips in the channel just under the sliding door and then down via I am assuming a water drain (incase water gets in to the sliding door cill)
This does not happen with the water from the kitchen sink only the hand basin in the bathroom
The questions I have are:
Regarding the Grey waste tank I am assuming that the pipes from the kitchen sink and the bathroom sink are separate and connect directly to the grey waste. Does anyone know if this is a correct assumption?
Given the difficulty of access due to the lack of access hatches would the pipes if they are directly connected be accessible if the grey tank is lowered?
Given this is a seal (or pipe failure) and whilst the vehicle is now out of warranty is it reasonable to ask for a contribution from Hymer to fix the water ingress ?
