Baily approach 745 Motorhome
bailey approach745
We have a Bailey approach 745 based on a Peugeot boxer, we changed the indicator bulb, how do you reset the light on the dashboard. Thanks
If the bulb failure light is still on you must still have a fault as once fixed the light will go out.
All lights are functioning okay expect the one on the dashboard. Thanks for replying
A bit odd on my Fiat which is basicly the same van when I've had a fault once the fault has cleared dash light has gone out.
Have you checked that the bulb you fitted is the same wattage as the original bulb ?
