Our Bailey Autograph (2017) won't shut down the habitation electrics. I press the On/Off button till it says "shutting down", it shuts down, but about 5 mins. later it switches back on.
Only things I had done prior to this was :-
1. Change the existing Truma pwm solar controller for a Victron SmartSolar mppt 75/15 - and connect the correct battery to it, Bailey had wired the batteries the wrong way round (battery 1 to the starter battery & battery 2 to the leisure battery, not a problem as it was set to 50/50 charging).
2. Move the BCA pdu forward so the top cover could be removed to confirm what mains charger was fitted.
Any suggestions as to the cause on the above problem?
