Bailey Autograph 79-6 (2018)
yeirrab
Notnray@123
Hello, I have just started getting ready for the new season and noticed that when I turned on the kitchen tap water was coming through the housing of the tap, I think I have since resolved this. However, I have tried to test the water and all I can hear are gurgling sounds and little or no water coming from taps? I am in the process of full draining down the water system but any suggestions would be helpful please?
Is your drain valve open for your water heater? Check under the van and see if you can see water coming out of a drain. Open all locker doors and make sure there is no water where it shouldn't be. You might actually have no water in the system if it's gurgling ESPECIALLY as you're in the process of draining down
Thank you! After drawing system I have closed all drain taps, filled 30% water, tried taps again and same issue? I have the pump on and it’s the same problem. I can hear the water gurgling but nothing coming through the tap spout. However, I can feel air on my hand when holding it under the tap.
If I get this problem, one remedy is to turn on the pump and take off the head off the shower and suck the water into the pump. Maybe its because the pump isn't the most powerful of the ones available. Doesn't seem to happen if I fill to 100%.
