Unless someone has changed the pump like I have it will be a Reich submersible pump with Reich micro switched taps.Are you sure it's a microswitch system rather than pressurised?
Yes sent that before saw the link to previous thread on the same subjectUnless someone has changed the pump like I have it will be a Reich submersible pump with Reich micro switched taps.
Do the sensible thing and fit a Sureflo, pump that's what I did, got fed up repairing the taps every 6 months. Also the water pressure is so much better.Hi, thanks to all for the posts. Found the screw at the back of tap, wasn’t even screwed in!! Removed it got to switch and as a lot of people said it had a broken wire, so back today with soldering iron and Glasses (might be able to see what im doing!!!)
