grasscutter
- Oct 11, 2009
- 2,687
- 10,686
- Hymer Exsis i588
- Started in 1980
I had B to B Victron 12v 30 amp fitted by the dealer when I had my lithiums fitted.
All working fine and no problems.
However, I have had a problem that I posted on an earlier thread with my Votronic Duo Solar regulator playing up and not charging and making a clicking noise.
The upshot of this problem is that I have bitten the bullet and changed to a Victron MPPT 100 30 solar controller and also fitting a battery master to top up the vehicle battery.
Now comes the part that makes me raise a question.
Whilst fitting the new solar I notice that the dealer has fitted the B to B with new cabling from the vehicle battery and then the output goes straight to the battery.
However the original cabling to the EBL is still in place so It appears the original split charge is still operational.
If I start the engine with the lithiums discharged down to 68% I get a reading on the smart shunt of 49.5amps input. The solar at this time is only producing 1.3 amps due to cloud cover.
Having read so many posts on the forum regarding the correct set up my thought was that to be correct ( in the easiest way) would be for the input to the EBL be disconnected and isolated and replaced with the output from the B to B.
Appreciate any comments as to what happens if I leave alone or adjust to what I suggested above.
Ive added some photos of the various Bluetooth readings ie
Solar readout.
B to B not running.
B to B running.
Smart Shunt with B to B running.
Hope all the above makes sense.
Graham
Solar readout.
B to B not running.
B to B running.
Graham
