What height is the awning rail when rolled in and what is the height of the Kampa? If the same should fit ok we did use an awning which was not quite high enough for a while used elastic loops to make up the difference see 235-265 is connection height if that helps.
Whilst a lot of the information/expertise is transferable, this is a 'motorhome' forum and you are most welcome. You may, however, find a caravan forum more useful.
