I don't have an awning, its to replace the infill that covers the screws on the rail of the motorhome, its also around the hab door and the gas locker.Make and model of awning? Rose Awnings may be able to help.
Herzim strip comes in a variety of widths up to a maximum of 17mm. which appears to be only available in black or white. The narrower widths are 11mm/12mm and 14mm and available in a variety of colours. Its correct name is Herzim strip but many suppliers refer to it as screw-cover strip. Have a look here at options. Perhaps posting a photo of what you are looking at would help.I did look at that but it seems to be wider than I need
Thanks for this, I will take photo next time I am at the motorhome.Herzim strip comes in a variety of widths up to a maximum of 17mm. which appears to be only available in black or white. The narrower widths are 11mm/12mm and 14mm and available in a variety of colours. Its correct name is Herzim strip but many suppliers refer to it as screw-cover strip. Have a look here at options. Perhaps posting a photo of what you are looking at would help.
Motorhome & Caravan Screw Cover Strip | Seals Direct
Huge choice of sizes and colours. Screw cover strips are used as a decorative trim to cover the screw heads and fixings in Aluminium channels and waist rails.www.sealsdirect.co.uk
and
Herzim Strip 12mm X 4mm Various Colours
Used as aesthetic trim in aluminium and other channels in Caravans and Motorhomes and various other applications. Material PVC Max Continuous Length 100M Weight 0.04kgcoh-baines.co.uk
