Awning height (1 Viewer)
Feb 15, 2024
18
4
Burstner
Hi guys my awning height is 260cm , I can get a really good deal on an awning but the minimum height is 280cm would this pose huge problems or could I make it work ? Thanks in advance
Jul 29, 2013
9,132
19,546
Salisbury
Hymer B678DL A class
since 2011
It might work if you have hydraulic levellers as you would be able to raise the height of your van however that would be an expensive way of doing it😊
76
66
Lincoln, UK
Bailey 79-4T
Feb 2023
The joker its the Kampa Air Ace brand new and half price , Really tempted
Must admit the right height is the key as pooling can cause an issue I just bought a rally air pro 330s £800 brand new from https://www.leisureshopdirect.com which I thought was a good deal and a good discount on accessories as well my rail was in the range quoted and fits spot on. Signed up for emails and put it in my basket and waited :giggle:
TheBig1
17,793
44,215
All awnings have a small amount of adjustment between minimum and maximum height. 20 cm or 8 inches is a big difference
2,800
9,814
Chester
Auto-trail
Well that`s our 14th year & still loving it.
As it's an Air awning can you adjust the length of the legs? we had one of the first Kampa air awnings that didn't have any adjustment in their length and unless the ground was level it looked awful with one or more of the legs bending.
At half price and not fitting it isn't such a good deal.
TheBig1
17,793
44,215
Just looked it up and the quoted range is 235cm to 295cm. So at 230 the awning would be baggy and misshapen on your van
4,203
5,215
Market Rasen
Self Build
Since 2003
Air awnings are quite heavy so I bought the Kampa Rally Pro 330 which has poles but much cheaper and lighter. Air awnings don’t work on a PVC as the door hits the middle beam.
76
66
Lincoln, UK
Bailey 79-4T
Feb 2023
5kg is 5kg I suppose:unsure: but it if the door hits the roof that would be a deal breaker🚪
  • Net weight 24 kg rally air pro
