Autotrial Tracker FB
just looking
First Post so be gentle
Need to some advice from Auto Trail Tracker owners, been looking for a while now to purchase our first motor home and love the Autotrail Tracker FB, but not sure if it will fit up my drive, Ok length wise worried about the width, the spec sheet says 2.35m/7"8 is this the main body width dimension or the cab with the mirrors out.
Was thinking if the cab is narrower i might have a chance, so does anyone know the cab width dimension and is the width the same above the cab. I could drive the Motor Home cab first into the narrowest point (would not be able to open the cab doors) but could exit through the main exit door.
Don't mind knocking the wall down & moving the gates
Is there anywhere that I could hire one from ?
Any help appreciated
Colin
Location Warrington Cheshire
2.35 is the main body width. Mirrors are extra but when folded are pretty much at 2.35. The overcab bit of the body tapers over the cab but not sure by how much and the van is in storage so unfortunately I can’t measure it for you. Good luck.
