Does anyone know how to take the rear light unit out of Autotrail Mohawk 2016...? Thanks Andy...
Rb62 is right also some screws behind 2 of the lights you will see them once the lights are out.I think you'll have to take all the lights out and disconnect them and I seem to remember the reflector is stuck on with double sided tape and there's a screw behind it.
Thanks ...Will do it tomorrow...AndyI thought there was a post on here somewhere but couldn't find it so here are some from elsewhere
'To remove the light you need to insert a small flat screwdriver between the plastic and the bottom edge of the light. I would place a cloth between the red plastic and the screwdriver so you do not mark the plastic. You will see a narrow slot in the base of the light. The light is held in place with a spring clip."
At the bottom of the light unit, under where it says "Hella", there is a channel. You need to make a thin tool bent into an L-shape at one end. Slide this into the channel with the "L" pointed up: push down and this will release the bottom of the light unit.'
