Ok, brain picking time for those of you that know stuff about batteries and chargers.
We have a 2011 Autotrail Arapaho which we have owned for about 5 years. It has a Sargent EC480 with a 125w solar panel on the roof and 2 x 110Ah leisure batteries. We have the Sargent’s smart charger setting enabled to charge both the leisure and engine battery as it see’s fit.
Recently we found that our leisure batteries were going flat – even when plugged into EHU.
I assumed that the leisure batteries were shot, and they probably were because we didn’t know how old they were and they kept dropping to about 10v. Either way we replaced them and we now have a shiny pair of 95751 Banners and I was hoping that the problem was fixed…..
We are now living on the van, long story but its a temporary stop gap after we sold the house in a moment of madness, and we have found…. you guessed it…… our new leisure batteries go flat, even when plugged into EHU.
If its really sunny the leisure batteries stay charged, so I am relatively confident that the solar panel is doing its thing. It seems to generate between .02 – 6A on the display depending on the sun and we can see that it switches between the engine and leisure batteries on the sun logo on the Sargent’s display. If I run the engine for say ½ an hour or so or if we drive somewhere the leisure’s charge back up again so I’m sure that the alternator is also working perfectly – in fact I had this checked by the Greenflag man during a call out for an unrelated issue!
The engine battery is fine – it’s a new battery courtesy of the unrelated matter I mentioned above and for which I still kick myself! The vans seems to start no matter how long we leave it, plugged in or not.
Whilst I'm happy to be corrected, I'm pretty sure that our charger has stopped charging either because the fuse has blown or because the unit itself has given up the ghost. I see on the fuse board that the charger is labelled as Fuse 15….. but there are only 14 fuses.
My questions are as follows.
Could it be anything else?
Where is the fuse for the charger? …… and before you think “this guy is a numpty, its next to the charger” let me confirm your suspicions and add that I also can’t find the charger – any idea where it is as well????
Going forward, the van is a few years old now and I guess that the technology has moved forward. If I did get the charger relaced, what should I replace it with? Like for like or upgrade it, and if so - to what? I've got new batteries so I'm unlikely to upgrade to Lithium in the next few years but it would be a shame to replace the charger now only for a future owner to have to replace it again if there is little differance in the cost.
Having read loads of other posts I'm pretty confident that most of you guys and gals are considerably more intelligent than I am, so please bear that in mind if you are kind enough to share your wisdom!
