Automobile TV camera
alan cooper
swift suntor 630l
Hi, i have a camera from a 2007 suntor which says Automobile TV on it
here is the photo
The unit is damaged, the motorhome has the perfect shape of that in with the trim so ideally i need an identical item, problem is its 2007 and i cant find an alternative or even know where to start, i suppose a could use a smaller item but thought id come on here for some help and guidance and there may well be a simple overall and better solution.
I only use it for when i use the reversing camera.
So long as youre not too fussed aesthetically then a piano hinge araldited on might work?
Brilliant answer, seriously though looking to replace the item, where would i start
Is it just a TV as you mention a "camera"?
one of these would work
lots of similar ones on ebay or amazon, but if size is an issue …. are you sure youre not my wife?
I wasn't thinking of alternative hinges. If all the parts are there it will repair invisibly.
Try removing the back of the monitor. It MUST have a make, model or serial number somewhere.
Nobody is going to make something without putting their name to it.
Put it back in place and then glue it all together and then buy a new TV and a rear view monitor for the dash. At least it will all be up to date then. If you do manage to find something in a scrap yard it's going to be from the same era 12 years old.
