Autocruise Alto Rear Light assembly
N Wales
Newbie
I have a crack in the rear light and would like to replace it but can't work out how. The internal panelling doesn't allow access to the rear of the assembly as would be possible in the van base.
Surely there is access to change the lamps when they fail?
Looking at the internal layout, if hatches have not been pre-cut to access the back of the lights it will be an awkward job to cut them neatly. I would use a vibrating multi tool after masking the area with tape and use a new blade on each side
There is a small panel between the door and the toilet cubiclewhich you can get your hand in but can't see inside so no idea how to what to use to release it .
Any help?
Thank you. That explains things . Now I know what releases the assembly I will remove the panel and see if I can undo the bolts by hand as it would be very difficult to get any tool in .
