Auto Trial Luton Front Top Marker Lights
Juke Box John
Stanford-le-Hope, UK
Auto Trail Delaware
Since 2012
I have an Auto Trail Frontier Delaware and the top Front Luton Marker Light has stopped working. I thought it was just a bulb but now have been told that I have to put in a new unit. Looking at it I am not sure how to remove this light unit as I do not want to damage forcing it out. Has anyone changed this component.
Mines a 2015 Delaware and the marker lights are Led, it looks like the lens just unclips off. It's possible the unit is held in place by a couple of self tappers.
Thanks for feedback. Red marker lights would be on the rear. I am attempting to change the front top marker light on the offside which has failed. It looks like it is just pushed into the black cover on the roof section but I do not want to damage roof cover by pulling it out.
I never mentioned the red marker lights, I said mine are L E D .
Upvote 1
A photograph of the offending item would be a big help.
On my van, you unscrew the lens, then the unit pulls out from the inside of the van and you need to remove some internal trim to access it. Some styles of light are just held in place by a rubber surround that you need to hook out with a small screwdriver or hooked piece of wire between the lens and the rubber surround.
On most marker lights I’ve seen they have a small water drainage hole . A small screwdriver inserted and gently prised upwards should flick the cover off. Hopefully
Juke Box John Is it like this?
front-jpg.406118
Had my nearside front and rear fail at the same time. For some unexplained reason, the front light live, is picked up from the rear light wiring. Took me a forever to find the exact fault, but defo more AT shoddy rubbish workmanship, just look at the state of the wiring when I removed it 🤷🏼‍♂️🤦🏼‍♂️
AT should hang their heads in shame at their workforce.
