Atoto S8 installation
Prov31Viv
Fiat Ducato Camperva
We have a 2019 fiat ducato that we are converting to a camper. We have bought Atoto S8 with 10" screen. We would really appreciate if anyone has fitted one of these if you could help us to figure out what we need to fit this in our van and where we could purchase it from. We need an installation kit but just not sure which one. We live in Ireland so if we purchase the incorrect kit it will be very expensive to return it.
The Ducato has a double DIN slot for the entertainment system. The 10" screen is too large to fit flush with the dash surround. If you read the advert (assuming on Amazon) they said the following in the description
"The front faceplate of its double-DIN base has the dimension of 178 * 100 (mm) and its 10.1-inch screen dimension is 252 * 155 (mm). The 10.1-inch floating display part stands out from its double din base allowing users to adjust height and view angles (up or down). For certain vehicles, the edge of the large screen may block the air vent, car emergency switch button, or other buttons, resulting in inconvenient operations."
If you fit it into the double DIN slot the screen will overlap with your air vents and will also probably cover parts of your heater controls. If you wanted it to fit flush I am afraid that you should have bought the 7" version instead. I doubt very much that you will be able to find an installation kit for this.
Thanks for reply but there is no problem with the screen covering the air vents at at all?
All that part is fine...we just struggling to find what wiring harness to buy.
