Assisted Air Suspension
Wolverhampton
Autocruise Select122
Since 2019
Hi Folks, Just bought An Autocruise Select it has Assisted air suspension but haven’t got any information on it, it hasnt got a compressor, not that that bothers me anyway , but i was wondering what sort of pressure was supposed to be in the system, only got a picture of manifold if anyone can help
Solution2
Easiest way empty the van of all loose gear, Measure from the rear jacking points to the ground with no air in the bags (don’t drive the van with less than 1 bar (15 psi) load the van as if going away, full fuel tank and water. Check the height then add air to get the same level as empty. That will give you starting pressure then add another bar(15 psi)
Did you ask the same question a couple of weeks ago 🤔
Anyway, I’d run it at about 3bar and close the valves when driving 👍
We were advised not to let it go below 1 bar but other than that, wherever suits your needs.
We rarely use our compressor, very convenient when you do need it though to raise the rear end for clearance.
You can use an ordinary car tyre pump to adjust the pressure.
Once you’ve set the pressure close the valves so that each side is isolated from the other.
Don't do "bars" so use 50psi on ours. Makes a nice stable ride without getting too firm or the back too high. A compressor is useful so you can change it at will, for instance raiding/lowering the rear, but we've managed for years without. I carry a tyre compressor anyway.
Thanks for the info just want to make sure i dont over inflate and cause irreparable damage, so running at 50 psi no problem?
Solution
