You have a better computer display than meI can see agm on the battery..
That sounds useful.Maybe a Schaudt WA 121545 above
Yes, if we buy this ML-T I would fit lithium asap, I wonder does that battery charger have a lithium option or perhaps change the whole unit.Difficult to tell from that photograph.
Hymer normally fit a Schaut EBL which is blue, but mine doesn't look like that.
The dealer should tell you what the batteries are and the blue box.
Nothing looks particularly abnormal. (and room to add a B2B if you want to go lithium)
Not sure it's that bad. Ours has been fine.The EBL on Gel has a 16 hour absorbtion phase which is not good for Lithium.
You had all your answers on another tread why do you keep going on about it.Schaudt's official guidance is to use the Gel setting. I know it may not be a perfect solution but it's not holding into LeFePO4 at 14.4V for ever. I cannot see how holding at 16 hours with no current in or out (unless top balancing) at the end of absorption is really going to harm in our application.
But that discussion was on float voltage not absorption duration. The Schaudt falls back to 13.7V float which although slightly higher than others would choose is not going to be an issue in practice.You had all your answers on another tread why do you keep going on about it.
Usually a 50A fuse for leisure batteries, and a small fuse, 3A maybe, for a thin voltage sensor wire that sends accurate battery voltage measurement to the EBL, unaffected by voltage drop along the main power wire. The starter battery trickle charge is usually by an entirely separate wire from EBL to the starter battery, which also carried power for the 12V element of the 3-way fridge.I can see on the original photo a sticker with 50amp fuse and 3amp fuse so I guess house batteries and trickle to engine??
