Anyone know where to get these?
Bristol, UK
Hymer B614SL
since 2020
My nearside rear indicator has been a bit intermittent over the past few days so I opened it up today to change the bulb and it appears the bulb holder is broken. It’s missing the plastic clips that keeps the tension.
Does anyone know where these can be purchased ideally avoiding the ‘Hymer tax’?
Links would be most welcome.
Doubt you'll get the individual part 🙁
The metal bit looks easily removable so go for the upgrade that PaulandChrissy will I’m sure be able to do for you. Then slot in the metal part.
You would need to carefully measure the part and model it in 3D, adding the missing clips. Hopefully you can find one of the broken ones.
Just had a whole light unit replaced as part of a no fault accident claim , £550+VAT 😳
Good luck 👍
Might sound over the top, but if you could send me the complete lamp and and all the bulb fittings, I can make you something more robust. Might be able to do it with just the fittings, but having the complete unit means I can be sure of a really reliable result. Would probably make it in carbon fibre nylon.
Let me know how you feel.
Cheers PaulandChrissy
