OkIs it on Ebay or a dealers website, it might help if Carthago owners on here can have a look.
its on eBay,Is it on Ebay or a dealers website, it might help if Carthago owners on here can have a look.
Yes it isThis one?
Fiat DUCATO MAXI DIESEL CARTHAGO CHIC 4/5 BERTH A CLASS MOTORHOME | eBay
Find many great new & used options and get the best deals for Fiat DUCATO MAXI DIESEL CARTHAGO CHIC 4/5 BERTH A CLASS MOTORHOME at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
L =7.6mLooking at upgrading my pvc. has anyone got a carthago chic with the 3 litre fiat engine with manual gearbox?
the one I’m looking at is a 2007.
looking for:~
dimensions l x w x h
mpg
any problems?
thanks in advance
Alex
Did you mean 5200kg.Check the payload, ours has been plated up to 4200,
Thank you DaveBrilliant van, massive garage. Old school built, ie proper built.
Ours is a 2.8 l I don't think it's a fiat engine .
Driving on the continent a dream, but be aware carthago spares are expensive and delivery via dealer from Germany is slow.
Check the payload, ours has been plated up to 4200, otherwise a small payload.
The leisure batteries are in an awkward position behind a panel in the garage.
Any more questions pm me..
I thought they started at 4250, can you actually run it legally at 4200 kg?Nope, 4200..
Just googled and found one at 3700kg so suspect they were available (albeit not practical) at 3500kg but running at 4250 should certainly be legally possible.I thought they started at 4250, can you actually run it legally at 4200 kg?
Mines around that with not a lot inI thought they started at 4250, can you actually run it legally at 4200 kg?
Had a look at the compact line but it’s way above my budget I’m afraid.We have a Cathargo Compactline which being 2.12 wide is much closer to the width of a PVC and the reason we bough it rather than a standard width A class. Having had 3 PVCs we didn't want to go fatter than we really had to as it restricted where we could go. Just something for you to consider.
Crazy money now you won't get a new one on the road for much under £125k which reflects in the second hand pricesHad a look at the compact line but it’s way above my budget I’m afraid.
Shame as they're great, however it also to make you think about whether the width will cause you an issue. After having the PVC we were adamant that we did not want anything much wider.Had a look at the compact line but it’s way above my budget I’m afraid.
