Only no its got a 3 pin plug but is running on 110 at the min and did not won't to risk trying the 240 on it as it's a good size so would not be cheep to replace the TV in the bed room is the same but I can get to the back of that one and see it has 110 on the back the rv spent a lot of time in Spain so tvs may be from there
Yes we have110 and 240v from any of the 2 gen sets or sites when we are on them we all so have 500w solar so was just going to run an inverter from battery bank
sorry.. can't help any more without actually seeing how it's been converted..
but the TVs must have been changed to PAL if they work in Europe..
best way to check what voltage it is, is to pull it out, and check the data label on the back..
Can you watch TV on it? Or do you just use it for the games?
You may find that the socket hasn't been converted, but the voltage has changed
Either meter the voltage at the socket, or as Jim said look at the spec plate on the back of the TV
When RV's are converted the "ring main" is normally pulled out of the 110 VAC distribution board, added to the new 220 VAC distribution board, and the outlets are changed to 13amp ones or blanked off/disconnected
At the rear of a TV cabinet perhaps access or space was restricted on the 110VAC socket wasn't changed. Not a good move in my opinion if that is the case given as it leads to issues like this.
Just got it off and it's 220-240 so don't no why last owner thort it was 110 thanks for the feedback everyone with out it I would have just gone with what I was told
