Anyone done this repair?
Suffolk
Lunar Roadstar 786
Since 2015
Good morning funsters,
I have some wood rot around the wheel arch on my 2005 Lunar Roadstar 786. Any advice would be appreciated -Broken Link Removed-
Doesn't look so bad that you couldn't attempt a repair yourself, or is it more extensive than it looks?
Morning,
I am doing it myself. Just after advice. What plywood is best? How do I seal it? What adhesive do I use to
What adhesive do I use to replace the panel? Maybe someone out there has done this repair before .
I would use marine ply and Sikaflex 292i marine adhesive, but I haven't done much of this kind of work for many years, someone with more current experience may be able to advise.
Edit: if you do use 292i make sure you read the notes on how to apply and use the activator and primer.
Hi As an ex boatbuilder I would tend to agree with Chris l remove all rotten and glue and screw new marine ply
Good luck
Thank you for the replies.
Has anyone used W4 mastic sealing strip to put a panel back on a MH
Good luck
What about any final treatments to the wood surfaces and edges before and after fitting to chassis?
Not mastic tapes but 3M make some really good double sided adhesive tape that can be used instead of screws, I used some on some quite heavy wood trim inside my van which kept falling off and it hasn't moved since.
marine ply shoulnt need sealing but a simple pva coating should be sufficient in my view
Again good luck
Again good luck
Marine ply is not impervious to water by any stretch of the imagination and PVA will do little better to improve that in that environment of a MH wheel arch.
What the OP needs in that environment is an epoxy resin and the product called West 105 with either their 205 or 206 hardener is absolutely the best bet, it will soak into the wood and have a super high water resistance.
Take a look on the projects page in the link below and you will see that the product is multi purpose, the West epoxy is widely sold in the UK, probably get it on Ebay.
I am shocked at the construction though but that is another story.
Would using something similar to this on the new wood help seal everything?
Amazon product ASIN B017J2V1IG
My belief based upon a few decades of working with the West system is that it will do everything and more than the Rustin product. the West will really bind flaking bits of wood back together and water proof at the same time.
Ideally completely new wood though, including that vertical batten behind the rotted out plywood.
292i has a stronger tensile strength at 2Mpa v 1.8 for 522 but Iexpect 522 will do the job.
Thank you everyone for your advice. Im very grateful. Looking in the ‘shed’ I’ve found a tin of Ronseal wood hardener. I’m going to use this on the marine ply before fixing to the MH
On my previous Dethleffs motorhome, the rear panels that were exposed to water a road dirt were attached by heavy duty Velcro rather than glue.
