We have an Autotrail Apache 2012. We also have two dogs, both escape artists. We have bought an airframe windbreak set to give them a play area outside the MoHo when we’re in France this summer. I have figured out how to seal the space between the side of the van and the ground, apart from the bit around the retractable step. I’ve bought a step to step from the hab door down to the ground but I want to disable the retractable step so I can seal the gap under the door to the ground, still have a step and when not using the windbreak have the retractable step back in working order. Hope that makes sense! Before I start a complete retractable step rewire has one of you good people installed a disabler switch or concocted a wiring mod that will solve my problem?
TIA!!
Russ
TIA!!
Russ
