Morning
I have a conundrum that needs some lateral thinking to solve.
Air tube awning (Dometic Rally Air Pro) has an air tube right by the hab door, which catches the corner of the door as it opens. It’s easy enough for me to give the tube a little upward shove as the door opens/closes to get it past, but it’s very annoying. It’s also not quite so easy for the other, shorter, passenger.
I’ve been thinking about a way to resolve this - current thinking is something like an extending curtain pole, vertical, with something to spread the load on the air tube. I’m thinking a piece of guttering packed with some foam perhaps. Maybe the connection from guttering to downpipe that I could fill in the downpipe bit so the pole sits inside.
Also something on the floor to spread the load at the bottom of the pole too.
Looking to see if anyone else has any ideas of how this could be solved before I start to source bits and pieces, or ideas of things to use?
Finally, I need to know the approx diameter of the tube to get a large enough piece of guttering. Not really in a position to go and pump it up right now, so anyone have one pumped up or access to the dimensions of the tube? My Google-foo isn’t working for me today as I’m unable to find that piece of info anywhere.
Thanks for listening, all help appreciated.
