Android file transfare on a galaxy 8 (1 Viewer)
andy63
4,672
15,019
south shields
None
since 1990
Im not savy when it comes to this sort of stuff..
I have a mac book air and a samsung galaxy 8 phone and wanted to transfare photos between the two..
Anyway it didnt work at first and most trouble shooting pointed you to this..
Turn on USB Debugging and choose "Media device (MTP)” option.
Thats all well and good but i could not find those options in a menu..
Apparently the newer phones have hidden features in the menu..
If you open settings and go to ' about phone '...then tap 7 times on ' software information' ..this opens something called 'developer options ' and in there you can change the settings i mentioned above...
That worked for me anyway...but what a carry on to find the correct settings.... why do they make it so hard....
Andy.
DBK
18,449
50,050
Plympton, Devon
PVC, Murvi Morocco
I had to do that on my Sony phone. I guess it is to stop folk fiddling with things. :) You would thinnk it would be set up to allow files to be transferred easily.
Apr 9, 2014
1,322
6,637
Lincs
I think most Android versions have this to enable access to developer options. But usually when you plug the phone into a computer with the correct lead the phone should offer up options on the phone to change the USB mode (charging, MTP etc...), sometimes have to drag down from the top to access.
andy63
andy63
4,672
15,019
south shields
None
since 1990
Hi Neil...if i remember i did get a notification about changing settings, but just wasnt able to find the ones i needed...
Like i said i had to tap 7 times on the software information tab in the about phone options to get to developer options where i found them. Oh Please! :xeek::xdoh: that would have been impossible to find , and even searching on you tube it took a while to get there...
If id been on the ball i should just have asked on here...
:xgrin:
Happy xmas btw:xThumb:
Andy
Jun 18, 2013
291
9,274
Essex, UK
Rapido 666F
Since 2015
There is a program available from Samsung for the Mac (and PC) called Smart Switch, which allows you to back up the 'phone and do a few other things. It's a bit of a sledgehammer to crack a nut approach if all you want is one photo but it does work quite well.
An app called AirDroid also promises to allow individual file transfer without plugging stuff in and presumably it works with most android 'phones. I downloaded it but can't be bothered with it, as the Smart Switch software works well enough.
